Saltar al contenido principal
HTC Desire 626s Charging Port Replacement
Qué necesitas
  1. HTC Desire 626s Charging Port Replacement, Backplate: paso 1, imagen 1 de 3 HTC Desire 626s Charging Port Replacement, Backplate: paso 1, imagen 2 de 3 HTC Desire 626s Charging Port Replacement, Backplate: paso 1, imagen 3 de 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Charging Port Replacement: paso 2, imagen 1 de 2 HTC Desire 626s Charging Port Replacement: paso 2, imagen 2 de 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Charging Port Replacement: paso 3, imagen 1 de 2 HTC Desire 626s Charging Port Replacement: paso 3, imagen 2 de 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Charging Port Replacement, Battery: paso 4, imagen 1 de 1
    • By using the angled tweezers, you have to be careful when you try to remove the battery connection by start pulling the wires.
  5. HTC Desire 626s Charging Port Replacement: paso 5, imagen 1 de 1
    • Using the plastic opening tool to separate the battery and remove it.
  6. HTC Desire 626s Charging Port Replacement: paso 6, imagen 1 de 1
    • Pull the battery out
  7. HTC Desire 626s Charging Port Replacement, Charging Port: paso 7, imagen 1 de 2 HTC Desire 626s Charging Port Replacement, Charging Port: paso 7, imagen 2 de 2
    • Using tweezers, peel back the plastic as shown in these two pictures.
    • You will need to pull it back as shown in picture 2 for future steps.
  8. HTC Desire 626s Charging Port Replacement: paso 8, imagen 1 de 1
    • Flip the white plastic piece up to a 90 degree angle.
    • Do this by using tweezers to grab the plastic, then gently lifting into position.
  9. HTC Desire 626s Charging Port Replacement: paso 9, imagen 1 de 1
    • Carefully lift the circuit board up and out.
    • Removal was easy with just fingers, but tweezers may be needed if there is resistance.
  10. HTC Desire 626s Charging Port Replacement: paso 10, imagen 1 de 3 HTC Desire 626s Charging Port Replacement: paso 10, imagen 2 de 3 HTC Desire 626s Charging Port Replacement: paso 10, imagen 3 de 3
    • Now that the circuit board is detached, the connecting wire needs to be removed.
    • Grasp the wire as shown in picture 2 at the red circle.
    • Pull straight up, perpendicular to the board. The wire pops off easily.
    • Tweezers may be used in place of fingers if you can not get a hold of this small wire and its connection.
  11. HTC Desire 626s Charging Port Replacement: paso 11, imagen 1 de 1
    • The new board will not go in as easily as the old one came out. Just be patient and squeeze the edges to clip it into place.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 749
