Introducción
This is a device removal guide for your HTC Desire 626s battery for replacement or hard reset.
Qué necesitas
Insert plastic opening tool in between the back cover and grey plastic.
Gently work your way around the phone while sliding the tool.
Gently pry on plastic cover as needed to release fasteners.
Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
By using the angled tweezers, you have to be careful when you try to remove the battery connection by start pulling the wires.
4 personas más completaron esta guía.
