Saltar al contenido principal
HTC Desire 626 Battery Replacement
Qué necesitas
  1. HTC Desire 626 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert an opening pick between the back cover and chassis, and pry around the perimeter until the back cover releases.
    • Remove the back cover.
  2. HTC Desire 626 Battery Replacement: paso 2, imagen 1 de 2 HTC Desire 626 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the "void" sticker over the screw near the top-right of the battery, and the larger one near bottom of the battery.
    • Don't worry about voiding warranties; those stickers are illegal in the US!
    • Use a Torx T5 screwdriver to remove the six screws.
    • Use a Phillips #000 screwdriver to remove the two screws.
  3. HTC Desire 626 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the white plastic frame with the opening tool.
  4. HTC Desire 626 Battery Replacement: paso 4, imagen 1 de 2 HTC Desire 626 Battery Replacement: paso 4, imagen 2 de 2
    • Use an ESD safe tool to carefully "walk" the battery connector out of its port.
    • Use an opening tool to lift the battery up and out of its housing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 432
