Saltar al contenido principal
HTC Desire 610 Charging Port Replacement
Qué necesitas
  1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: paso 1, imagen 1 de 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: paso 1, imagen 2 de 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: paso 1, imagen 3 de 3
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Charging Port Replacement: paso 2, imagen 1 de 1
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Charging Port Replacement: paso 3, imagen 1 de 1
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Charging Port Replacement: paso 4, imagen 1 de 1
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Charging Port Replacement: paso 5, imagen 1 de 1
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Charging Port Replacement, Charging Port: paso 6, imagen 1 de 1
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  7. HTC Desire 610 Charging Port Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, disconnect the antenna wire.
  8. HTC Desire 610 Charging Port Replacement: paso 8, imagen 1 de 3 HTC Desire 610 Charging Port Replacement: paso 8, imagen 2 de 3 HTC Desire 610 Charging Port Replacement: paso 8, imagen 3 de 3
    • Peel back the gray adhesive strip using the precision tweezers.
  9. HTC Desire 610 Charging Port Replacement: paso 9, imagen 1 de 1
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  10. HTC Desire 610 Charging Port Replacement: paso 10, imagen 1 de 3 HTC Desire 610 Charging Port Replacement: paso 10, imagen 2 de 3 HTC Desire 610 Charging Port Replacement: paso 10, imagen 3 de 3
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  11. HTC Desire 610 Charging Port Replacement: paso 11, imagen 1 de 3 HTC Desire 610 Charging Port Replacement: paso 11, imagen 2 de 3 HTC Desire 610 Charging Port Replacement: paso 11, imagen 3 de 3
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
Conclusión
2 personas más completaron esta guía.
Kaycee Hammond
Miembro Desde 02/11/17
273 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Wilson Spring 2017 Miembro de IUPUI, Team S1-G1, Wilson Spring 2017
IUPUI-WILSON-S17S1G1
4 Miembros
6 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,243
