Introducción
If the screen of your HTC Desire 530 is broken or cracked, this guide will give you step by step help in order to replace the screen on your own. For this guide, you will need plastic opening tools, T5 Torx screwdriver, and a suction cup. The screen is fragile so use extra caution.
Herramientas
Partes
No se especificaron partes.
Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
Use the T5 Torx screwdriver to remove the four screws in each corner.
Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
After the battery has been removed, there are two screws that also need to be removed
There are two gold strips that you must disconnect from the motherboard, They simply pop right off.
2 personas más completaron esta guía.
