Saltar al contenido principal
Introducción
This guide is only if your device does not charge when you plug the device into the Micro USB Port. If this is the scenario it means that the port you have in currently is broken and can't recognize when the cable is entered into the HTC device. In order to replace this component you will need to separate the screen from the body so you can access the insides and dig your way down to the port and replace it with a new one that functions properly.
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: paso 1, imagen 1 de 1
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: paso 2, imagen 1 de 1
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: paso 3, imagen 1 de 1
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: paso 4, imagen 1 de 1
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: paso 5, imagen 1 de 1
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: paso 6, imagen 1 de 1
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
Conclusión
Eric Blackstock
Miembro Desde 24/10/18
379 Reputación
2 Guías creadas
Equipo
UMASSD-PEAK-F18S3G2 Miembro de UMASSD-PEAK-F18S3G2
Community
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 490
