Saltar al contenido principal
HTC Desire 530 Micro USB Port Replacement
Qué necesitas
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: paso 1, imagen 1 de 1
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: paso 2, imagen 1 de 1
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: paso 3, imagen 1 de 1
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: paso 4, imagen 1 de 1
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: paso 5, imagen 1 de 1
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: paso 6, imagen 1 de 1
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
Conclusión
Una persona más ha completado esta guía.
Eric Blackstock
Miembro Desde 10/24/18
403 Reputación
2 Guías creadas
Equipo
UMASSD-PEAK-F18S3G2 Miembro de UMASSD-PEAK-F18S3G2
Community
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 591
