Saltar al contenido principal
HTC Desire 510 Earpiece Replacement
Qué necesitas
Resumen del Video
  1. HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: paso 1, imagen 1 de 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: paso 1, imagen 2 de 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: paso 1, imagen 3 de 3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: paso 2, imagen 1 de 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: paso 2, imagen 2 de 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: paso 2, imagen 3 de 3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: paso 3, imagen 1 de 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: paso 3, imagen 2 de 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: paso 3, imagen 3 de 3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: paso 4, imagen 1 de 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: paso 4, imagen 2 de 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: paso 4, imagen 3 de 3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Earpiece Replacement, EARPIECE: paso 5, imagen 1 de 1
    • The earpiece is in the upper part of the middle panel.
Conclusión
4 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
194,516 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 327
1,692 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,582
