Saltar al contenido principal
HTC Desire 310 Micro USB Port Replacement
Qué necesitas
    • The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
Conclusión
2 personas más completaron esta guía.
Alex Sander
Miembro Desde 02/28/17
38,219 Reputación
202 Guías creadas
4 comentarios
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Keith Weisberger - Contestar
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Alex Sander -
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
It would be nice if you had explained what you were doing during the removal. What was that goo you put on it and how did it work to remove the old part?
andrew - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 710
