Saltar al contenido principal
HTC Amaze Motherboard Replacement
Qué necesitas
  1. HTC Amaze Motherboard Replacement, Battery: paso 1, imagen 1 de 2 HTC Amaze Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Motherboard Replacement: paso 2, imagen 1 de 1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: paso 3, imagen 1 de 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: paso 3, imagen 2 de 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: paso 3, imagen 3 de 3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Motherboard Replacement: paso 4, imagen 1 de 3 HTC Amaze Motherboard Replacement: paso 4, imagen 2 de 3 HTC Amaze Motherboard Replacement: paso 4, imagen 3 de 3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Motherboard Replacement: paso 5, imagen 1 de 2 HTC Amaze Motherboard Replacement: paso 5, imagen 2 de 2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
  6. HTC Amaze Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 HTC Amaze Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 HTC Amaze Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Locate and remove the Phillips J000 screw.
  7. HTC Amaze Motherboard Replacement: paso 7, imagen 1 de 2 HTC Amaze Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the power supply from the motherboard by gently pulling the end of the black wire with the precision tweezers.
  8. HTC Amaze Motherboard Replacement: paso 8, imagen 1 de 3 HTC Amaze Motherboard Replacement: paso 8, imagen 2 de 3 HTC Amaze Motherboard Replacement: paso 8, imagen 3 de 3
    • First, gently lift the black strip by pulling. It will take a little force and then it will disconnect.
    • Next remove the yellow mylar tape using the precision tweezers.
  9. HTC Amaze Motherboard Replacement: paso 9, imagen 1 de 3 HTC Amaze Motherboard Replacement: paso 9, imagen 2 de 3 HTC Amaze Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the jawbone connector that was under the mylar tape by gently pulling with the precision tweezers.
    • Now gently pull the motherboard away from its housing. You'll now have access to the bottom side of the motherboard.
  10. HTC Amaze Motherboard Replacement: paso 10, imagen 1 de 3 HTC Amaze Motherboard Replacement: paso 10, imagen 2 de 3 HTC Amaze Motherboard Replacement: paso 10, imagen 3 de 3
    • Locate a second jawbone connector covered by mylar tape at the bottom of the back of the motherboard.
    • Remove the tape by pulling gently with the precision tweezers.
    • Remove the jawbone connector with the precision tweezers.
  11. HTC Amaze Motherboard Replacement: paso 11, imagen 1 de 2 HTC Amaze Motherboard Replacement: paso 11, imagen 2 de 2
    • Carefully pull the motherboard out of its recess.
Conclusión
2 personas más completaron esta guía.
Akshat Shah
Miembro Desde 09/26/16
368 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 16-3, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 525
