Qué necesitas
Remove the back cover of the device to access the internal components of the HTC 7 Surround.
To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Una persona más ha completado esta guía.
