Saltar al contenido principal
HTC 7 Surround Camera Replacement
Qué necesitas
  1. HTC 7 Surround Camera Replacement, Back Case: paso 1, imagen 1 de 2 HTC 7 Surround Camera Replacement, Back Case: paso 1, imagen 2 de 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: paso 2, imagen 1 de 3 HTC 7 Surround Camera Replacement: paso 2, imagen 2 de 3 HTC 7 Surround Camera Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: paso 3, imagen 1 de 1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: paso 4, imagen 1 de 1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 175
