Saltar al contenido principal
HP-Pavillion 500-424 PC Series CPU Fan Replacement
Qué necesitas
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: paso 1, imagen 1 de 2 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: paso 1, imagen 2 de 2
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 2, imagen 1 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 2, imagen 2 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 2, imagen 3 de 3
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 3, imagen 1 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 3, imagen 2 de 3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: paso 3, imagen 3 de 3
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
Conclusión
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
2 personas más completaron esta guía.
Amanda Milby
Miembro Desde 09/13/18
177 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 40
Todo El Tiempo: 1,899
