Saltar al contenido principal
HP w2216h Power Supply Replacement
Qué necesitas
  1. HP w2216h Power Supply Replacement, Screen: paso 1, imagen 1 de 1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Power Supply Replacement: paso 2, imagen 1 de 2 HP w2216h Power Supply Replacement: paso 2, imagen 2 de 2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Power Supply Replacement: paso 3, imagen 1 de 3 HP w2216h Power Supply Replacement: paso 3, imagen 2 de 3 HP w2216h Power Supply Replacement: paso 3, imagen 3 de 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Power Supply Replacement: paso 4, imagen 1 de 3 HP w2216h Power Supply Replacement: paso 4, imagen 2 de 3 HP w2216h Power Supply Replacement: paso 4, imagen 3 de 3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Power Supply Replacement: paso 5, imagen 1 de 2 HP w2216h Power Supply Replacement: paso 5, imagen 2 de 2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Power Supply Replacement: paso 6, imagen 1 de 3 HP w2216h Power Supply Replacement: paso 6, imagen 2 de 3 HP w2216h Power Supply Replacement: paso 6, imagen 3 de 3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Power Supply Replacement: paso 7, imagen 1 de 3 HP w2216h Power Supply Replacement: paso 7, imagen 2 de 3 HP w2216h Power Supply Replacement: paso 7, imagen 3 de 3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Power Supply Replacement, Power Supply: paso 8, imagen 1 de 1
    • Monitor power supplies can be dangerous. Read ifixit's monitor safety guide before working with power supplies.
    • Remove the cables connecting the power supply to the display port.
  9. HP w2216h Power Supply Replacement: paso 9, imagen 1 de 1
    • Remove the four 8mm Phillips #000 head screws connecting the power supply to the screen assembly.
  10. HP w2216h Power Supply Replacement: paso 10, imagen 1 de 1
    • Lift the power supply vertically out of the screen assembly
Conclusión
Una persona más ha completado esta guía.
Branflakes222
Miembro Desde 03/25/16
399 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Miles Spring 2016 Miembro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 808
