Saltar al contenido principal
HP w2216h Power Button Replacement
Qué necesitas
  1. HP w2216h Power Button Replacement, Power Button: paso 1, imagen 1 de 3 HP w2216h Power Button Replacement, Power Button: paso 1, imagen 2 de 3 HP w2216h Power Button Replacement, Power Button: paso 1, imagen 3 de 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: paso 2, imagen 1 de 1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: paso 3, imagen 1 de 1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
Conclusión
2 personas más completaron esta guía.
Sadeq Taha
Miembro Desde 03/25/16
219 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-1, Miles Spring 2016 Miembro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 610
