Saltar al contenido principal
HP w2216h Control Buttons Replacement
Qué necesitas
  1. HP w2216h Control Buttons Replacement, Control Buttons: paso 1, imagen 1 de 1
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
  2. HP w2216h Control Buttons Replacement: paso 2, imagen 1 de 2 HP w2216h Control Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Control Buttons Replacement: paso 3, imagen 1 de 3 HP w2216h Control Buttons Replacement: paso 3, imagen 2 de 3 HP w2216h Control Buttons Replacement: paso 3, imagen 3 de 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Control Buttons Replacement: paso 4, imagen 1 de 1
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Control Buttons Replacement: paso 5, imagen 1 de 1
    • Remove the plastic buttons from the contacts
  6. HP w2216h Control Buttons Replacement: paso 6, imagen 1 de 2 HP w2216h Control Buttons Replacement: paso 6, imagen 2 de 2
    • Remove the wire connecting the contacts to the screen assembly.
Conclusión
Una persona más ha completado esta guía.
Patrick Aucoin
Miembro Desde 03/25/16
221 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Miles Spring 2016 Miembro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 351
