Saltar al contenido principal
HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: paso 1, imagen 1 de 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: paso 2, imagen 1 de 2 HP rp5700 Cover Removal Replacement: paso 2, imagen 2 de 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: paso 3, imagen 1 de 3 HP rp5700 Cover Removal Replacement: paso 3, imagen 2 de 3 HP rp5700 Cover Removal Replacement: paso 3, imagen 3 de 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
Conclusión
11 personas más completaron esta guía.
Alyssa Briones
Miembro Desde 01/21/14
1,699 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 6-23, Maness Winter 2014 Miembro de Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 77
Todo El Tiempo: 21,531
