Saltar al contenido principal
HP iPAQ h4155 LCD screen replacement
Qué necesitas
  1. HP iPAQ h4155 LCD screen replacement, Battery: paso 1, imagen 1 de 1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 LCD screen replacement: paso 2, imagen 1 de 1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 LCD screen replacement: paso 3, imagen 1 de 1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 LCD screen replacement, Back Case: paso 4, imagen 1 de 1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 LCD screen replacement: paso 5, imagen 1 de 1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 LCD screen replacement: paso 6, imagen 1 de 2 HP iPAQ h4155 LCD screen replacement: paso 6, imagen 2 de 2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 LCD screen replacement: paso 7, imagen 1 de 1
    • Remove the back case.
  8. HP iPAQ h4155 LCD screen replacement, Face Plate: paso 8, imagen 1 de 1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 LCD screen replacement: paso 9, imagen 1 de 2 HP iPAQ h4155 LCD screen replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 LCD screen replacement: paso 10, imagen 1 de 2 HP iPAQ h4155 LCD screen replacement: paso 10, imagen 2 de 2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 LCD screen replacement: paso 11, imagen 1 de 1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: paso 12, imagen 1 de 2 HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: paso 12, imagen 2 de 2
    • Now that the front cover is removed we can detach the screen
    • Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
  13. HP iPAQ h4155 LCD screen replacement: paso 13, imagen 1 de 3 HP iPAQ h4155 LCD screen replacement: paso 13, imagen 2 de 3 HP iPAQ h4155 LCD screen replacement: paso 13, imagen 3 de 3
    • Now the screen can be removed
Conclusión
Una persona más ha completado esta guía.
John Pagliero
Miembro Desde 01/27/11
942 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 1,552
