Saltar al contenido principal
HP iPAQ h4155 Backup Battery Replacement
Qué necesitas
  1. HP iPAQ h4155 Backup Battery Replacement, Battery: paso 1, imagen 1 de 1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 Backup Battery Replacement: paso 2, imagen 1 de 1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 Backup Battery Replacement: paso 3, imagen 1 de 1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 Backup Battery Replacement, Back Case: paso 4, imagen 1 de 1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 Backup Battery Replacement: paso 5, imagen 1 de 1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 Backup Battery Replacement: paso 6, imagen 1 de 2 HP iPAQ h4155 Backup Battery Replacement: paso 6, imagen 2 de 2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 Backup Battery Replacement: paso 7, imagen 1 de 1
    • Remove the back case.
  8. HP iPAQ h4155 Backup Battery Replacement, Face Plate: paso 8, imagen 1 de 1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 Backup Battery Replacement: paso 9, imagen 1 de 2 HP iPAQ h4155 Backup Battery Replacement: paso 9, imagen 2 de 2
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 Backup Battery Replacement: paso 10, imagen 1 de 2 HP iPAQ h4155 Backup Battery Replacement: paso 10, imagen 2 de 2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 Backup Battery Replacement: paso 11, imagen 1 de 1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 Backup Battery Replacement, JoyPad buttons: paso 12, imagen 1 de 1
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  13. HP iPAQ h4155 Backup Battery Replacement: paso 13, imagen 1 de 2 HP iPAQ h4155 Backup Battery Replacement: paso 13, imagen 2 de 2
    • Once removed you can easily separate the keys from the body.
  14. HP iPAQ h4155 Backup Battery Replacement, Backup Battery: paso 14, imagen 1 de 2 HP iPAQ h4155 Backup Battery Replacement, Backup Battery: paso 14, imagen 2 de 2
    • once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
Conclusión
4 personas más completaron esta guía.
John Pagliero
Miembro Desde 01/27/11
942 Reputación
7 Guías creadas
2 comentarios
This guide is AWESOME.. Thanks! I have an iPAQ 1945 h1900, but this guide was the exact same for my device. I got as far as the taking the battery out without removing the 5th screw beneath the "warranty void" sticker. My only issue--do you know where to get the replacement battery?
Drew Stafford - Contestar
IMPORTANT. The back up battery does not show charge immediately ( i don't know why ) Id read something before. When in April 2023 i swapped the old B U Batt for a known good one from another ipaq. At the end of the job . The level of charge on the b.up was zero. I charged the main batt to 100% then removed the ipaq from the charger and left it for a couple of hours . When I next checked it there was 100% on both batts....
Ron - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 3,511
