Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP iPAQ HW6515 Flash LED Bulb Replacement
Qué necesitas
    1. HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: paso 1, imagen 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: paso 1, imagen 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: paso 1, imagen 3 de 3
      • Flip the HP iPAQ HW6515 over with the screen facing down.
      • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
      • Place the back of the case aside for now.
      Pregunta a FixBot
      Agregar Comentario
    2. HP iPAQ HW6515 Flash LED Bulb Replacement: paso 2, imagen 1 de 1
      • Remove the battery by pulling up on the black tab.
      Pregunta a FixBot
      Agregar Comentario
    1. HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: paso 3, imagen 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: paso 3, imagen 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: paso 3, imagen 3 de 3
      • Unscrew the four screws using the T6 hexagonal star screwdriver.
      • Unscrew the middle screw using the Phillips 00 screwdriver.
      • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
      Pregunta a FixBot
      Agregar Comentario
    2. HP iPAQ HW6515 Flash LED Bulb Replacement: paso 4, imagen 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: paso 4, imagen 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: paso 4, imagen 3 de 3
      • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
      • Slide the plastic opening tool along the seam until the two halves of the case separate.
      Pregunta a FixBot
      Agregar Comentario
    3. HP iPAQ HW6515 Flash LED Bulb Replacement: paso 5, imagen 1 de 2 HP iPAQ HW6515 Flash LED Bulb Replacement: paso 5, imagen 2 de 2
      • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
      Pregunta a FixBot
      Agregar Comentario
    4. HP iPAQ HW6515 Flash LED Bulb Replacement: paso 6, imagen 1 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: paso 6, imagen 2 de 3 HP iPAQ HW6515 Flash LED Bulb Replacement: paso 6, imagen 3 de 3
      • Gently pull off the black rubber square covering the LED light.
      • The LED is now exposed.
      • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
      • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Steven Vo
Miembro Desde 04/02/12
33 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-17, Forte Spring 2012 Miembro de Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
Miembros de 4
20 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 1,628
