Saltar al contenido principal
HP iPAQ H2200 LCD Screen Replacement
Qué necesitas
  1. HP iPAQ H2200 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 LCD Screen Replacement: paso 2, imagen 1 de 2 HP iPAQ H2200 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 LCD Screen Replacement, Main Board: paso 3, imagen 1 de 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 LCD Screen Replacement: paso 6, imagen 1 de 3 HP iPAQ H2200 LCD Screen Replacement: paso 6, imagen 2 de 3 HP iPAQ H2200 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 LCD Screen Replacement: paso 7, imagen 1 de 2 HP iPAQ H2200 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 LCD Screen Replacement: paso 9, imagen 1 de 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 LCD Screen Replacement: paso 11, imagen 1 de 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 LCD Screen Replacement, LCD Screen: paso 12, imagen 1 de 1
    • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  13. HP iPAQ H2200 LCD Screen Replacement: paso 13, imagen 1 de 2 HP iPAQ H2200 LCD Screen Replacement: paso 13, imagen 2 de 2
    • Press on side tabs to loosen and remove the LCD screen.
Conclusión
Una persona más ha completado esta guía.
Tyler Andrews
Miembro Desde 01/13/10
209 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-12, Forte Winter 2010 Miembro de Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 3,976
