Saltar al contenido principal
HP eStation Zeen Motherboard Replacement
Qué necesitas
  1. HP eStation Zeen Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 HP eStation Zeen Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 HP eStation Zeen Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: paso 2, imagen 1 de 3 HP eStation Zeen Motherboard Replacement: paso 2, imagen 2 de 3 HP eStation Zeen Motherboard Replacement: paso 2, imagen 3 de 3
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: paso 4, imagen 1 de 1
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: paso 7, imagen 1 de 2 HP eStation Zeen Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: paso 8, imagen 1 de 2 HP eStation Zeen Motherboard Replacement: paso 8, imagen 2 de 2
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: paso 9, imagen 1 de 2 HP eStation Zeen Motherboard Replacement: paso 9, imagen 2 de 2
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
Conclusión
Una persona más ha completado esta guía.
dalton hale
Miembro Desde 09/26/16
503 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 16-4, Eyestone Fall 2016 Miembro de USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 555
