Saltar al contenido principal
HP dv5-1125nr RAM Replacement
Qué necesitas
  1. HP dv5-1125nr RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr RAM Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr RAM Replacement: paso 4, imagen 1 de 2 HP dv5-1125nr RAM Replacement: paso 4, imagen 2 de 2
    • Remove the RAM cover to reveal the module's underneath.
  5. HP dv5-1125nr RAM Replacement: paso 5, imagen 1 de 3 HP dv5-1125nr RAM Replacement: paso 5, imagen 2 de 3 HP dv5-1125nr RAM Replacement: paso 5, imagen 3 de 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
Conclusión
3 personas más completaron esta guía.
Nick Loey
Miembro Desde 04/01/14
1,676 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 942
