Saltar al contenido principal
HP dv5-1125nr Display Replacement
Qué necesitas
  1. HP dv5-1125nr Display Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Display Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Display Replacement, Hard Drive: paso 3, imagen 1 de 2 HP dv5-1125nr Display Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Display Replacement: paso 4, imagen 1 de 1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Display Replacement: paso 5, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 5, imagen 2 de 2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Display Replacement: paso 6, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 6, imagen 2 de 2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Display Replacement: paso 7, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 7, imagen 2 de 2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr Display Replacement, RAM: paso 8, imagen 1 de 1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  9. HP dv5-1125nr Display Replacement: paso 9, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 9, imagen 2 de 2
    • Remove the RAM cover to reveal the module's underneath.
  10. HP dv5-1125nr Display Replacement: paso 10, imagen 1 de 3 HP dv5-1125nr Display Replacement: paso 10, imagen 2 de 3 HP dv5-1125nr Display Replacement: paso 10, imagen 3 de 3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
  11. HP dv5-1125nr Display Replacement, Keyboard: paso 11, imagen 1 de 1
    • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
  12. HP dv5-1125nr Display Replacement: paso 12, imagen 1 de 1
    • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
  13. HP dv5-1125nr Display Replacement: paso 13, imagen 1 de 1
    • Unscrew the 4mm Phillips screw inside the hard drive bay.
    • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
  14. HP dv5-1125nr Display Replacement: paso 14, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 14, imagen 2 de 2
    • Locate the hole in between the hard drive and RAM compartments.
    • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
    • Unscrew the 4mm Phillips head screw from this hole.
  15. HP dv5-1125nr Display Replacement: paso 15, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 15, imagen 2 de 2
    • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
    • You may need to use the opening tool on both sides of the cover.
    • Be careful not to break the ribbon cables under the cover.
  16. HP dv5-1125nr Display Replacement: paso 16, imagen 1 de 1
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
  17. HP dv5-1125nr Display Replacement: paso 17, imagen 1 de 1
    • Dislodge the keyboard to access the underside.
    • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
  18. HP dv5-1125nr Display Replacement: paso 18, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 18, imagen 2 de 2
    • Locate the ribbon cable connection between the keyboard and motherboard.
    • Pull upwards on the small black bar to release the ribbon cable and remove it.
    • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
  19. HP dv5-1125nr Display Replacement: paso 19, imagen 1 de 1
    • The keyboard is now ready for replacement.
  20. HP dv5-1125nr Display Replacement, Display: paso 20, imagen 1 de 3 HP dv5-1125nr Display Replacement, Display: paso 20, imagen 2 de 3 HP dv5-1125nr Display Replacement, Display: paso 20, imagen 3 de 3
    • Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
  21. HP dv5-1125nr Display Replacement: paso 21, imagen 1 de 2 HP dv5-1125nr Display Replacement: paso 21, imagen 2 de 2
    • Locate the two ribbon cable connectors that attach the speaker assembly to the motherboard.
    • Using your fingers, carefully detach the ribbon cables from the motherboard by pulling them straight out on the connector.
  22. HP dv5-1125nr Display Replacement: paso 22, imagen 1 de 1
    • Remove the speaker assembly from the keyboard tray.
  23. HP dv5-1125nr Display Replacement: paso 23, imagen 1 de 1
    • Locate the large display ribbon connector near the upper left corner of the keyboard tray and remove the ribbon by pulling straight out on the connector.
  24. HP dv5-1125nr Display Replacement: paso 24, imagen 1 de 1
    • The display should now be loose, but make sure to remove all ribbon connectors before attempting to take off the display.
    • Locate the two final ribbon connectors for the display on the motherboard and remove them similarly by pulling straight outward on the connectors.
    • You are now free to remove the display from the computer.
Conclusión
12 personas más completaron esta guía.
Nick Loey
Miembro Desde 04/01/14
1,715 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
Miembros de 4
10 Guías creadas
1 Guide Comment
Where can i buy the display?
Fabio Benedetti - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 27
Todo El Tiempo: 4,098
