Saltar al contenido principal
HP dv5-1125nr Disk Drive Replacement
Qué necesitas
  1. HP dv5-1125nr Disk Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: paso 3, imagen 1 de 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: paso 3, imagen 2 de 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: paso 4, imagen 1 de 3 HP dv5-1125nr Disk Drive Replacement: paso 4, imagen 2 de 3 HP dv5-1125nr Disk Drive Replacement: paso 4, imagen 3 de 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Conclusión
Nick Loey
Miembro Desde 04/01/14
1,688 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 733
