Saltar al contenido principal
HP dv5-1125nr CMOS Battery Replacement
Qué necesitas
  1. HP dv5-1125nr CMOS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr CMOS Battery Replacement, CMOS Battery: paso 3, imagen 1 de 2 HP dv5-1125nr CMOS Battery Replacement, CMOS Battery: paso 3, imagen 2 de 2
    • Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
  4. HP dv5-1125nr CMOS Battery Replacement: paso 4, imagen 1 de 2 HP dv5-1125nr CMOS Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Locate the CR2032 watch battery
    • Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
  5. HP dv5-1125nr CMOS Battery Replacement: paso 5, imagen 1 de 1
    • The CMOS battery is now removed from your system.
Conclusión
10 personas más completaron esta guía.
Cory Mayer
Miembro Desde 04/01/14
891 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 8,458
