Saltar al contenido principal
HP dv5-1125nr Battery Replacement
Qué necesitas
  1. HP dv5-1125nr Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
Conclusión
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 personas más completaron esta guía.
Nick Loey
Miembro Desde 04/01/14
1,676 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 9-15, Regan Spring 2014 Miembro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Miembros
10 Guías creadas
2 comentarios
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Contestar
what is your return policy?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 1,195
