Saltar al contenido principal
HP ZBook 15 Optical Drive Replacement
Qué necesitas
  1. HP ZBook 15 Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 HP ZBook 15 Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: paso 2, imagen 1 de 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  4. HP ZBook 15 Optical Drive Replacement: paso 4, imagen 1 de 3 HP ZBook 15 Optical Drive Replacement: paso 4, imagen 2 de 3 HP ZBook 15 Optical Drive Replacement: paso 4, imagen 3 de 3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
Conclusión
4 personas más completaron esta guía.
Grant Terris
Miembro Desde 01/30/15
2,828 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 8-43, Amido Winter 2015 Miembro de Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Miembros
15 Guías creadas
2 comentarios
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - Contestar
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 28
Todo El Tiempo: 6,734
