Introducción
This is the top cover to access the interior components of the HP Z2 Mini G3 (Product No. 1LE81UP#ABA). This guide can direct you to remove the panel.
Be sure to turn off the device and disconnect the A/C power cord before removing the panel.
Components inside the device are also subject to static damage, so try and work on a hard surface to reduce this risk.
Casi Terminas!
Conclusión
