Saltar al contenido principal
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Qué necesitas
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: paso 1, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: paso 1, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: paso 1, imagen 3 de 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: paso 2, imagen 1 de 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: paso 2, imagen 2 de 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: paso 3, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: paso 3, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: paso 3, imagen 3 de 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: paso 4, imagen 1 de 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: paso 4, imagen 2 de 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: paso 5, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: paso 5, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: paso 5, imagen 3 de 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S18-G5, White Winter 2019 Miembro de Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 1,577
