Saltar al contenido principal
HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
Qué necesitas
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: paso 1, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: paso 1, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: paso 1, imagen 3 de 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: paso 2, imagen 1 de 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: paso 2, imagen 2 de 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 3, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 3, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 3, imagen 3 de 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 4, imagen 1 de 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 4, imagen 2 de 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: paso 5, imagen 1 de 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: paso 5, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 6, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 6, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 6, imagen 3 de 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: paso 7, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: paso 7, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: paso 7, imagen 3 de 3
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 8, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 8, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 8, imagen 3 de 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 9, imagen 1 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 9, imagen 2 de 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: paso 9, imagen 3 de 3
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
Conclusión
4 personas más completaron esta guía.
Eeshan Mishra
Miembro Desde 01/24/19
424 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S1-G2, Maness Spring 2019 Miembro de Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Miembros
7 Guías creadas
Un comentario
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
Baba Nam Kevalam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,868
