Saltar al contenido principal
HP TouchSmart 15-r015dx Keyboard Replacement
Qué necesitas
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: paso 2, imagen 1 de 3 HP TouchSmart 15-r015dx Keyboard Replacement: paso 2, imagen 2 de 3 HP TouchSmart 15-r015dx Keyboard Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: paso 3, imagen 1 de 3 HP TouchSmart 15-r015dx Keyboard Replacement: paso 3, imagen 2 de 3 HP TouchSmart 15-r015dx Keyboard Replacement: paso 3, imagen 3 de 3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-4, Watkins Winter 2015 Miembro de USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 3,047
