Introducción
Use this guide to replace a broken display data cable.
Herramientas
Partes
No se especificaron partes.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Use the edge of a plastic opening tool to peel up the self-adhesive pull tab stuck to the display data cable.
Una persona más ha completado esta guía.
