Introducción
If you're looking to fix the speaker on your HP Stream 11 x360-p015wm laptop, then boy are you in the right place. This guide will take you step-by-step through how to get right to your speaker and take it out! Then, follow the steps in reverse order to put it back together!
Qué necesitas
Orient the laptop to have the back cover facing upwards.
Remove the four rubber pads located in each corner.
Herramienta utilizada en este paso:iFixit Opening Tool$1.99
Open the laptop and orient the keyboard facing upward.
Slowly wedge the opening tool into the gap between the keyboard and the back cover.
After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
Locate your speaker on the left and right ends of the front rear side of your laptop.
