Saltar al contenido principal
HP Stream x360 11-p015wm Battery Replacement
Qué necesitas
  1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: paso 1, imagen 1 de 2 HP Stream x360 11-p015wm Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Battery Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    JIS Driver Set
    $19.99
    Comprar
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Battery Replacement: paso 3, imagen 1 de 2 HP Stream x360 11-p015wm Battery Replacement: paso 3, imagen 2 de 2
    iFixit Opening Tool
    $1.99
    Comprar
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Battery Replacement: paso 4, imagen 1 de 2 HP Stream x360 11-p015wm Battery Replacement: paso 4, imagen 2 de 2
    $3.99
    Comprar
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Battery Replacement, Battery: paso 5, imagen 1 de 3 HP Stream x360 11-p015wm Battery Replacement, Battery: paso 5, imagen 2 de 3 HP Stream x360 11-p015wm Battery Replacement, Battery: paso 5, imagen 3 de 3
    • Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
  6. HP Stream x360 11-p015wm Battery Replacement: paso 6, imagen 1 de 3 HP Stream x360 11-p015wm Battery Replacement: paso 6, imagen 2 de 3 HP Stream x360 11-p015wm Battery Replacement: paso 6, imagen 3 de 3
    • Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
    • Remove the wire located on the top side of the battery.
    • All connections should be removed. Simply remove the battery from the computer.
Conclusión
DaisyHaskell
Miembro Desde 10/15/18
683 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 528
