Saltar al contenido principal
HP Stream TPN-Q155 Keyboard replacement
Qué necesitas
  1. HP Stream TPN-Q155 Keyboard replacement, HP Stream TPN-Q155 Keyboard replacement: paso 1, imagen 1 de 1
    • Unscrew all the screws on the back of the laptop and remove the cover
  2. HP Stream TPN-Q155 Keyboard replacement: paso 2, imagen 1 de 2 HP Stream TPN-Q155 Keyboard replacement: paso 2, imagen 2 de 2
    • Remove the black adhesive to expose plastic rivets.
  3. HP Stream TPN-Q155 Keyboard replacement: paso 3, imagen 1 de 3 HP Stream TPN-Q155 Keyboard replacement: paso 3, imagen 2 de 3 HP Stream TPN-Q155 Keyboard replacement: paso 3, imagen 3 de 3
    • Now, get a tissue and prepare for the sweat.
    • And melt any rivet from green marker to orange marker like. Try not to cut it off, or you might be in trouble to hold the metal cover
  4. HP Stream TPN-Q155 Keyboard replacement: paso 4, imagen 1 de 2 HP Stream TPN-Q155 Keyboard replacement: paso 4, imagen 2 de 2
    • Same process and keep melting the rest of the plastic rivets after the metal cover. This can easily going over 2 or 3 hours if you are not quick enough.
    • And if everything goes alright, you might eventually get the problem keyboard removed and put a new keyboard back in.
    • then, use your solder station the melt the plastic back to the keyboard.
Conclusión
Jim Yang
Miembro Desde 02/06/17
112 Reputación
1 Guía escrita
Equipo
Jim The Computer Man Miembro de Jim The Computer Man
Business
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 1,106
