Saltar al contenido principal
HP Stream 8 Motherboard Replacement
Qué necesitas
  1. HP Stream 8 Motherboard Replacement, Midframe: paso 1, imagen 1 de 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: paso 4, imagen 1 de 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: paso 7, imagen 1 de 1
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: paso 10, imagen 1 de 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: paso 11, imagen 1 de 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: paso 12, imagen 1 de 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the motherboard from the device.
Conclusión
Una persona más ha completado esta guía.
Nick Miller
Miembro Desde 04/11/16
669 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-14, Maness Spring 2016 Miembro de Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 1,140
