Saltar al contenido principal
HP Stream 7 Battery Replacement
Qué necesitas
  1. HP Stream 7 Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Stream 7 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
  2. HP Stream 7 Battery Replacement: paso 2, imagen 1 de 2 HP Stream 7 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
  3. HP Stream 7 Battery Replacement: paso 3, imagen 1 de 2 HP Stream 7 Battery Replacement: paso 3, imagen 2 de 2
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
Conclusión
3 personas más completaron esta guía.
Nelson Thai
Miembro Desde 10/02/16
233 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-5, Forte Fall 2016 Miembro de Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 6,829
