Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Stream 14-CB174WM Speakers Replacement
Qué necesitas
  1. HP Stream 14-CB174WM Speakers Replacement, Lower Case: paso 1, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement, Lower Case: paso 1, imagen 2 de 2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
    Pregunta a FixBot
    Agregar Comentario
  2. HP Stream 14-CB174WM Speakers Replacement: paso 2, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
    Pregunta a FixBot
    Agregar Comentario
  3. HP Stream 14-CB174WM Speakers Replacement: paso 3, imagen 1 de 3 HP Stream 14-CB174WM Speakers Replacement: paso 3, imagen 2 de 3 HP Stream 14-CB174WM Speakers Replacement: paso 3, imagen 3 de 3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
    Pregunta a FixBot
    Agregar Comentario
  4. HP Stream 14-CB174WM Speakers Replacement, Battery: paso 4, imagen 1 de 3 HP Stream 14-CB174WM Speakers Replacement, Battery: paso 4, imagen 2 de 3 HP Stream 14-CB174WM Speakers Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the following Phillips screws that secure the battery:
    • Three 2.9 mm
    • Two 6.8 mm
    • Be sure to keep different screw types separate from one another throughout the battery removal process.
    Pregunta a FixBot
    Agregar Comentario
  5. HP Stream 14-CB174WM Speakers Replacement: paso 5, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement: paso 5, imagen 2 de 2
    • Use your fingers or the point of a spudger to slowly “wiggle” the battery connector directly out of its socket.
    • Do not pull on the wires.
    Pregunta a FixBot
    Agregar Comentario
  6. HP Stream 14-CB174WM Speakers Replacement: paso 6, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement: paso 6, imagen 2 de 2
    • Gently unseat the battery connector wire out from under the two plastic tabs.
    Pregunta a FixBot
    Agregar Comentario
  7. HP Stream 14-CB174WM Speakers Replacement: paso 7, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement: paso 7, imagen 2 de 2
    • Lift the battery up and out of the laptop.
    • The battery should lift out with very little effort. If the battery cannot easily be lifted out of the laptop chassis, check to see if you missed any screws.
    Pregunta a FixBot
    Agregar Comentario
  8. HP Stream 14-CB174WM Speakers Replacement, Speakers: paso 8, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement, Speakers: paso 8, imagen 2 de 2
    • Use a Phillips screwdriver to remove the four 6.6 mm screws that secure the speakers.
    Pregunta a FixBot
    Agregar Comentario
  9. HP Stream 14-CB174WM Speakers Replacement: paso 9, imagen 1 de 1
    • Use two plastic opening tools to "walk" the speaker connector directly out of its motherboard port.
    Pregunta a FixBot
    Agregar Comentario
  10. HP Stream 14-CB174WM Speakers Replacement: paso 10, imagen 1 de 2 HP Stream 14-CB174WM Speakers Replacement: paso 10, imagen 2 de 2
    • Wedge an opening tool underneath one corner of the speakers and prop that side of the speaker upwards.
    • Repeat this for both sides of the speakers.
    • You will hear cracking sounds during this process. This is normal.
    Pregunta a FixBot
    Agregar Comentario
  11. HP Stream 14-CB174WM Speakers Replacement: paso 11, imagen 1 de 1
    • Lift the speakers up and out of the laptop chassis.
    • The speakers should be loose and easily come out of the laptop chassis with little to no force. If it does not, repeat the previous step.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 312
