Saltar al contenido principal
HP Stream 13-c110nr Display Replacement
Qué necesitas
  1. HP Stream 13-c110nr Display Replacement, Keyboard Assembly: paso 1, imagen 1 de 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Display Replacement: paso 2, imagen 1 de 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Display Replacement: paso 3, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 3, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 3, imagen 3 de 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Display Replacement: paso 4, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 4, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Display Replacement: paso 5, imagen 1 de 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Display Replacement: paso 6, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 6, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 6, imagen 3 de 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Display Replacement: paso 7, imagen 1 de 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Display Replacement: paso 8, imagen 1 de 2 HP Stream 13-c110nr Display Replacement: paso 8, imagen 2 de 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Display Replacement: paso 9, imagen 1 de 2 HP Stream 13-c110nr Display Replacement: paso 9, imagen 2 de 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Display Replacement: paso 10, imagen 1 de 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Display Replacement, Display Assembly: paso 11, imagen 1 de 1
    • Disconnect the Display Cable from the System Board.
  12. HP Stream 13-c110nr Display Replacement: paso 12, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 12, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 12, imagen 3 de 3
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws from the screen retaining brackets.
    • Place the four (4) screws on the magnetic mat for reassembly.
  13. HP Stream 13-c110nr Display Replacement: paso 13, imagen 1 de 2 HP Stream 13-c110nr Display Replacement: paso 13, imagen 2 de 2
    • Peel off two (2) stickers located at the bottom corners of the display assembly.
    • Place two (2) stickers in safe place for reassembly.
  14. HP Stream 13-c110nr Display Replacement: paso 14, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 14, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 14, imagen 3 de 3
    • Remove the two (2) Phillips P0 PM2.5x2.0 mm screws.
    • Place the two (2) screws on the magnetic mat for reassembly.
  15. HP Stream 13-c110nr Display Replacement: paso 15, imagen 1 de 3 HP Stream 13-c110nr Display Replacement: paso 15, imagen 2 de 3 HP Stream 13-c110nr Display Replacement: paso 15, imagen 3 de 3
    • Use a pick to pry off the display cover from the display.
  16. HP Stream 13-c110nr Display Replacement: paso 16, imagen 1 de 1
    • Remove the Display Assembly.
  17. HP Stream 13-c110nr Display Replacement: paso 17, imagen 1 de 2 HP Stream 13-c110nr Display Replacement: paso 17, imagen 2 de 2
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws.
    • Place four (4) screws on magnetic mat for reassembly.
    • Remove the two (2) Phillips P0 PM2.5x3.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  18. HP Stream 13-c110nr Display Replacement: paso 18, imagen 1 de 1
    • Separate display from back cover
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 312
