Saltar al contenido principal
HP Stream 13-c010nr Wi-Fi Card Replacement
Qué necesitas
  1. HP Stream 13-c010nr Wi-Fi Card Replacement, HP Stream 13-c010nr Disassembly: paso 1, imagen 1 de 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Wi-Fi Card Replacement: paso 2, imagen 1 de 2 HP Stream 13-c010nr Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Wi-Fi Card Replacement: paso 3, imagen 1 de 2 HP Stream 13-c010nr Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Wi-Fi Card Replacement: paso 4, imagen 1 de 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Wi-Fi Card Replacement, Wi-Fi Card: paso 5, imagen 1 de 1
    • Slide the Wi-Fi card out from the motherboard.
Conclusión
Keegan Lapham
Miembro Desde 02/22/18
759 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G3, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 266
