Saltar al contenido principal
HP Stream 13-c010nr USB Port Replacement
Qué necesitas
  1. HP Stream 13-c010nr USB Port Replacement, laptop: paso 1, imagen 1 de 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr USB Port Replacement: paso 2, imagen 1 de 2 HP Stream 13-c010nr USB Port Replacement: paso 2, imagen 2 de 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr USB Port Replacement: paso 3, imagen 1 de 2 HP Stream 13-c010nr USB Port Replacement: paso 3, imagen 2 de 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr USB Port Replacement: paso 4, imagen 1 de 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr USB Port Replacement, USB Port: paso 5, imagen 1 de 2 HP Stream 13-c010nr USB Port Replacement, USB Port: paso 5, imagen 2 de 2
    • Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  6. HP Stream 13-c010nr USB Port Replacement: paso 6, imagen 1 de 2 HP Stream 13-c010nr USB Port Replacement: paso 6, imagen 2 de 2
    • Remove the three 3mm Phillips #0 screws from the USB port.
    • Pull out the USB port.
  7. HP Stream 13-c010nr USB Port Replacement: paso 7, imagen 1 de 1
    • Remove the chip containing the two USB Ports.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Keegan Lapham
Miembro Desde 02/22/18
759 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G3, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 351
