Introducción
Use this guide to remove the lower case of the HP Stream 11-d020nr. This should take you about 5-10 minutes. Use caution when taking the cover off of the laptop. The process requires a significant amount of force, and it can be easy to damage the internal components.
Herramientas
Partes
No se especificaron partes.
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Una persona más ha completado esta guía.
