Saltar al contenido principal
HP Stream 11-d010nr Wifi Chip Replacement
Qué necesitas
  1. HP Stream 11-d010nr Wifi Chip Replacement, Keyboard: paso 1, imagen 1 de 2 HP Stream 11-d010nr Wifi Chip Replacement, Keyboard: paso 1, imagen 2 de 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Wifi Chip Replacement: paso 2, imagen 1 de 1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Wifi Chip Replacement: paso 3, imagen 1 de 2 HP Stream 11-d010nr Wifi Chip Replacement: paso 3, imagen 2 de 2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Wifi Chip Replacement: paso 4, imagen 1 de 1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Wifi Chip Replacement: paso 5, imagen 1 de 3 HP Stream 11-d010nr Wifi Chip Replacement: paso 5, imagen 2 de 3 HP Stream 11-d010nr Wifi Chip Replacement: paso 5, imagen 3 de 3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Wifi Chip Replacement: paso 6, imagen 1 de 1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Wifi Chip Replacement, Battery: paso 7, imagen 1 de 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
  8. HP Stream 11-d010nr Wifi Chip Replacement: paso 8, imagen 1 de 2 HP Stream 11-d010nr Wifi Chip Replacement: paso 8, imagen 2 de 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
  9. HP Stream 11-d010nr Wifi Chip Replacement, Wifi Chip: paso 9, imagen 1 de 2 HP Stream 11-d010nr Wifi Chip Replacement, Wifi Chip: paso 9, imagen 2 de 2
    • Unplug the black wire attached to the wireless chip.
  10. HP Stream 11-d010nr Wifi Chip Replacement: paso 10, imagen 1 de 2 HP Stream 11-d010nr Wifi Chip Replacement: paso 10, imagen 2 de 2
    • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
    • Lift the wireless chip up and out.
Conclusión
Una persona más ha completado esta guía.
Zachary Heisler
Miembro Desde 01/24/19
352 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S1-G3, White Winter 2019 Miembro de Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 590
