Introducción
If the webcam in you HP Stream 11-d010nr is showing signs of being faulty or damaged, such as not displaying video, it may need to be replaced. This guide will show you the steps necessary to do so.
Qué necesitas
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Remove any tape holding the battery connector in place.
Using your fingers, carefully unplug the battery.
