Introducción
Replace RAM
- If you are experiencing a sudden performance decrease in your device with additional crashes in your system device or crashes during set-up and lastly a blue screen of death this indicates you need to replace your RAM.
- Follow the steps on this guide to help replace your RAM without any struggles. Before, you initiate these steps it is important you save any prior data if possible.
- Make sure you power off your device completely and disconnect any external power source.
- Gather your tools and new RAM to start making the changes instructed below.
Qué necesitas
Remove battery by pushing slide tabs to the left.
Remove residual power by holding the power button down for 5 seconds.
Use a Phillips #1 screwdriver to remove the two 12.5 mm screws, four 5.5 mm screws, and six 7.25 mm screws.
Remove the two corner panels along the ends of the battery slot and this will expose another set of screws (1 under each panel).
Remove the remaining six 7.2 mm Phillips #1 screws hidden in the battery area and underneath the covers.
2 personas más completaron esta guía.
2 comentarios
Awesome job. this is a nice guide
If you could post another guide on how to clean the fans and heatsink and rethemopasting. I will look at it give you 30 more points. Thanks
