Introducción
Replace the Battery
- If the device is overheating, not charging, or experiencing short run times and shutdowns this may mean there is a faulty battery. You will need to open your device and replace the battery.
- Before you begin, make sure to take the time to inspect the potential symptoms that indicate the device issue is relating to the battery.
- Make sure to have a new battery that matches the systems device.
- Before you begin ensure the device is turned off and disconnected from any external power source.
- Proceed to follow the guide steps to successfully replace a faulty battery.
Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
Install the new battery into the port and press down gently.
Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
Device should be working as usual with the new battery.
Una persona más ha completado esta guía.
Un comentario
Altho this a simple fix some people still have a hard time removing the battery so thank you very much
