Introducción
This guide will show how to remove the malfunctioning flash circuit board in the HP Sprocket 2-in-1 device. The guide uses tools from the iFixit Pro Tech Tool Kit. This guide contains steps which involve removal of very delicate ribbon cables, be sure to avoid tugging and pulling as they can easily tare and cause the need for replacement.
Qué necesitas
Using a Japanese Industrial Standard (J) screwdriver (J00 bit), remove three 2.5mm screws connecting the flash circuit board to the housing.
