Introducción
This guide will showcase the steps necessary to remove the HP Sprocket 2-in-1 camera assembly in case of a fault. Be careful when doing so in a dusty environment as dust can impact image quality after the reinstalling a new lens. Furthermore, be sure to complete this guide in a well-lit environment to avoid potential issues that can arise when handling very small screws.
Qué necesitas
Use the Japanese Industrial Standard J00 screwdriver to remove five 2.5mm screws.
Remove the metal plate from the casing.
