Saltar al contenido principal
HP Split x2 13-g210dx Speakers Replacement
Qué necesitas
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: paso 1, imagen 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: paso 3, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: paso 4, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 4, imagen 2 de 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: paso 5, imagen 1 de 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: paso 6, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 6, imagen 2 de 2
    Comprar
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: paso 7, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 7, imagen 2 de 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: paso 8, imagen 1 de 1
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: paso 9, imagen 1 de 1
  10. HP Split x2 13-g210dx Speakers Replacement: paso 10, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 10, imagen 2 de 2
    Comprar
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: paso 11, imagen 1 de 1
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: paso 12, imagen 1 de 1
  13. HP Split x2 13-g210dx Speakers Replacement: paso 13, imagen 1 de 3 HP Split x2 13-g210dx Speakers Replacement: paso 13, imagen 2 de 3 HP Split x2 13-g210dx Speakers Replacement: paso 13, imagen 3 de 3
    Comprar
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: paso 14, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 14, imagen 2 de 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: paso 15, imagen 1 de 1
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: paso 16, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement, Speakers: paso 16, imagen 2 de 2
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: paso 17, imagen 1 de 2 HP Split x2 13-g210dx Speakers Replacement: paso 17, imagen 2 de 2
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: paso 18, imagen 1 de 3 HP Split x2 13-g210dx Speakers Replacement: paso 18, imagen 2 de 3 HP Split x2 13-g210dx Speakers Replacement: paso 18, imagen 3 de 3
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 291
